Vision web browser component issue
Hi, I’ve just downloaded and installed the vision web browser component and it doesn’t seems to work.
If I add the component on my view, I have the following error message when trying to open the view:
If I delete the component my view can open again.
Any idea??
Thanks,
Can you click that “full” button and put the details here too? What version of the module did you download?
It’s version 4.0.12.
Here’s the details :
com.inductiveautomation.ignition.common.xmlserialization.SerializationException: Unexpected parsing error during binary deserialization.
	at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer.deserializeBinary(XMLDeserializer.java:358)
	at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer.deserialize(XMLDeserializer.java:259)
	at com.inductiveautomation.factorypmi.application.model.WindowCache._deserializeWindow(WindowCache.java:374)
	at com.inductiveautomation.factorypmi.application.model.WindowCache._loadWindow(WindowCache.java:317)
	at com.inductiveautomation.factorypmi.application.model.WindowCache.openWindow(WindowCache.java:291)
	at com.inductiveautomation.factorypmi.application.VisionDesktop$RuntimeWindowOpener.openWindow(VisionDesktop.java:490)
	at com.inductiveautomation.factorypmi.application.VisionDesktop.openWindow(VisionDesktop.java:197)
	at com.inductiveautomation.factorypmi.application.VisionDesktop.openWindow(VisionDesktop.java:189)
	at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilities.lambda$swapWindow$0(NavUtilities.java:197)
	at com.inductiveautomation.factorypmi.application.script.builtin.WindowUtilities.doGUIAction(WindowUtilities.java:808)
	at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilities.swapWindow(NavUtilities.java:196)
	at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilitiesDispatcher.swapWindow(NavUtilitiesDispatcher.java:99)
	at jdk.internal.reflect.GeneratedMethodAccessor444.invoke(Unknown Source)
	at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:188)
	at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:520)
	at org.python.core.PyObject.__call__(PyObject.java:497)
	at org.python.core.PyObject.__call__(PyObject.java:501)
	at org.python.pycode._pyx157.f$0(<event:mousePressed>:7)
	at org.python.pycode._pyx157.call_function(<event:mousePressed>)
	at org.python.core.PyTableCode.call(PyTableCode.java:171)
	at org.python.core.Py.runCode(Py.java:1614)
	at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:771)
	at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.runActions(ActionAdapter.java:200)
	at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.invoke(ActionAdapter.java:291)
	at com.inductiveautomation.factorypmi.application.binding.action.RelayInvocationHandler.invoke(RelayInvocationHandler.java:57)
	at com.sun.proxy.$Proxy46.mousePressed(Unknown Source)
	at java.desktop/java.awt.AWTEventMulticaster.mousePressed(Unknown Source)
	at java.desktop/java.awt.EventQueue$5.run(Unknown Source)
Caused by: org.apache.commons.io.IOExceptionWithCause: java.lang.ClassNotFoundException: com.inductiveautomation.webbrowser.BrowserComponent
	at com.inductiveautomation.ignition.common.xmlserialization.encoding.Decoders$ClassDecoder.binaryToObject(Decoders.java:398)
	at com.inductiveautomation.ignition.common.xmlserialization.encoding.Decoders$ClassDecoder.binaryToObject(Decoders.java:359)
	at com.inductiveautomation.ignition.common.xmlserialization.deserialization.BinaryParser.readAttributes(BinaryParser.java:179)
	at com.inductiveautomation.ignition.common.xmlserialization.deserialization.BinaryParser.readElement(BinaryParser.java:148)
	at com.inductiveautomation.ignition.common.xmlserialization.deserialization.BinaryParser.readElement(BinaryParser.java:157)
	at com.inductiveautomation.ignition.common.xmlserialization.deserialization.BinaryParser.parse(BinaryParser.java:51)
	at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer.deserializeBinary(XMLDeserializer.java:349)
	... 59 more
Caused by: java.lang.ClassNotFoundException: com.inductiveautomation.webbrowser.BrowserComponent
	at java.base/java.net.URLClassLoader.findClass(Unknown Source)
	at java.base/java.lang.ClassLoader.loadClass(Unknown Source)
	at java.base/java.lang.Class.forName0(Native Method)
	at java.base/java.lang.Class.forName(Unknown Source)
	at com.inductiveautomation.ignition.common.xmlserialization.ClassNameResolver.classForNameImpl(ClassNameResolver.java:196)
	at com.inductiveautomation.ignition.common.xmlserialization.ClassNameResolver.classForName(ClassNameResolver.java:169)
	at com.inductiveautomation.ignition.common.xmlserialization.encoding.Decoders$ClassDecoder.binaryToObject(Decoders.java:388)
	... 69 more
Ignition v8.0.10 (b2020031912)
Java: Azul Systems, Inc. 11.0.6
If you go to Help -> About Ignition Designer (from inside the designer) can you confirm the web browser module is showing up with a valid state? Or check the designer logs on a fresh startup - see if there’s an error about not being able to load the module for some reason.
Ah, he said this got fixed by upgrading to Ignition 8.0.12 to match the module version, but that info got moved away into the new topic.
