Vision window - only vertical scrollbar
Hello everyone!
I’m trying to create a long scrollable Vision window, what I’d like is to have only the vertical scrollbar visible.
It’s something similar to what was discussed in this thread. I’ve tried following the suggestions there, as well as other solutions from both the manual and this forum.
However, both scrollbars still appear, even though the content fits perfectly horizontally, so the horizontal one barely moves and shouldn’t really be there at all.
Is there a way to have only the vertical scrollbar appear?
I’m using Ignition 8.1.43.
Thanks in advance!
This thread was for a popup, but the same method should apply.
It works! Thank you!
