Visual Client cannot connect to Gateway
Good morning,
I am currently using the ignition 8.1.11. On my machine, I can launch the Client without any issues. However, when trying to deploy the client on an HMI I am having issues connecting to the gateway. I have been able to ping both the host PC from the HMI via VNC so I do not believe it to be a connection issue. I've imported the application from the visual client on the host PC to the HMI and tried using Local host and IP:Port to see the gateway without any success. It's probably going a silly detail that I'm missing but any ideas would be welcome.
Where is the gateway located ie what machine is it on? Are the proper firewall ports opened up on that machine to allow incoming connections?
The gateway is located on my PLC, and no, the firewall port was not open which was blocking the connection. Thank you for the help!
Glad you got it working.
Can you mark my post as the solution? That will help others out.
