Voice module with TTS French voice -- certificate has expired
@Kevin.Herron
I try to install the voice module with TTS french voice, but it seems that the certificate has expired:
Is there a new release ?
Ignition doesn't actually care about expired certificates. It is just an extra warning to you.
Phil's right, but we are aware of this and somebody will get around to this in a sprint and re-publish the modules soon I think.
I added a redundant node to an existing with this module and I was not able have the backup node ok complaigning about module mismatch. I will test again
module load error was due to cere_dll in use. gateway restart and module reinstall on master to sync backup node solved my issue
