Voice Notification Atcom IP02 setup issues
Hello,
I’m am trying to setup Voice Notifications using the Atcom IP02 SIP device. I’ve read through the white paper explaining setup with IP01 and the few forum threads on this device but have hit a wall.
When testing an alarm I can see that the pipeline is active in Status/Alarm Pipelines but under Status/Voice Alarming pending calls remain 0. More so in Status/Logs I have the following 2 errors
Agent 06Apr2018 02:29:17 cannot find invite client transaction for call MxgDogeM-1523017756775@pemKaleoDesktop
CallManager 06Apr2018 02:29:16 Error state received from call manager. Reason: Not Found [404]
As for my setup I have both the voice notification and voice modules installed and gateway restarted after install. The Alarm Notification Profile for the IP02 is setup with user and password of the VoIP extension and the status is Registered with VOIP Host. I double checked the IP02 settings and that looks good based on other post and manual.
Has anyone ran into this issue or have any ideas on what I could test next?
Thank you
Kaleo
This means that Ignition is trying to reach your SIP server to initiate the call - but whatever endpoint we're talking to is giving back a generic '404' error. Make sure that you're using the correct outbound address and port.
Thanks PGriffith,
Finally got a chance to work on it today. Not able to see the problem after double checking my settings. This is on a test bench right now and setting are:
Atcom IP02 gateway IP 192.168.1.100
FXS Extension: 6101 / Voice Mail disabled
Voip Extension: 6000 / Password: atcom / Voice Mail: disabled
Outbound Routes: Name: admin
Pattern: _1NXXNXXXXXX
Extension: 6000
Trunk: FXO2 (Analog Trunk port 2)
SIP Settings: UDP Port: 5060 (made sure router port forward set incase needed)
TCP Port: 5060 (tried with and without)
Ignition Notification Settings
Gateway: Address 192.168.1.100
User: 6000
Password: atcom
I think that covers it. Anyone got suggestion or see where I went wrong? Or see missing info that’s needed?
Any help is appreciated
Hey PEM.Kaleo,
Did you ever find a solution to this issue? I too am using an Atcom IP02 for voice notification. I have it connected to ignition and it acts like its making a phone call, but I am not receiving it on my phone.
So this thread might be 7 years old, but the problem we had today was exactly like the issue discussed by OP.
The trick I figured out is very similar to what was recommended in another thread to refresh the OPC-UA connection, to find the connection, edit and then immediately save the configuration to force Ignition to reload the config.
In this case, do not restart the modules, especially if you have TTS Voice together with the Voice Notification modules active and running. Restarting either creates a fault condition where both are affected. If that happens, you have to restart the ignition gateway service.
But, back to the error notified in by the OP.
Ignition Web Gateway > Config > Alarming > Alarm Notification Profiles
find the "Voip Voice Notification" Profile affected, it will be green saying "Registered with VOIP Host".
Click Edit > then dont touch any settings, just scroll down to the bottom and click "Save Changes"
This will force the gateway to reload the configuration, and in our case, it will refresh the Voip Voice Notification connection. Which should help you recover the voip service.
one recomendation, is in the gateway logs, find "alarm.Notfiication.Voice.CallManager" and enable TRACE to each logger. That will give you all the info you need to identify the error, and to see the connection "refresh" itself and calls going out as normal.
