Voice Notification Module - TLS 1.2 support?
HI,
Our IT department is having issues registering the 7.9 voice notification module with a WebEx Calling SIP service, they believe the issue is that the notification module doesn't support TLS 1.2... Has anyone successfully configured a WebEx Calling notification pipeline? Does the 8.1 module work with TLS 1.2?
Thanks in advance,
Dan
Besides my first suggestion being you should upgrade to 8.1, you might have to reach out to support on this. There are a lot of changelogs between 7.9 and 8.1 to search through to see if this was set up, but someone with support could probably get you the answer quicker than anyone here can unless one of the developers involved in that module sees your post.
Support. This forum is not an official support venue.
Thanks for the response, Michael, we are running a legacy 7.9 gateway for our MES 1.0 project in parallel with a few 8.1 gateways... Waiting for 8.3 / MES 4.0 to upgrade our 7.9 gateway! I'll give it a try on our 8.1 server!
Nope, the 8.1 gateway fails to register too... Back to the drawing board!
