Voice Notification: Pipeline stops after aknowledged rosters
Hello,
I am experiencing a problem with the voice notification module in Ignition 8.1.41, everything appears to be an Ignition problem.
I have AWS Chime running without any issues, calls and roasters are running without a problem. User actions on the phone are recorded correctly in the gateway audit logs, including the end of the call.
The problem occurs after the end of an aknowledged roaster; the pipeline does not continue. If I place a script after the call block, after a valid & aknowledged call, this block is not executed. No errors are shown in the logs.
On the contrary, if I run the pipeline with a roaster without users or in test mode, then the script block is executed without errors. The script also runs with a valid roster, but only if everyone in the roster refuses to aknowledge the alarm.
OS: Windows Server 2022 (only Ignition installed).
For anyone wondering, script block is just a print.
Thanks!!!
This may sound obvious, but...
Did you make sure to uncheck this ?
Not that obvious, I did not know that config even existed... :joy:
That solved the problem! Sorry for the inconvenience, my bad...
Thanks @pascal.fragnoud
