VOIP voice notifications, initial call not going out
Voice notifications work correctly after merely saving the alarm pipeline between initiation of various alarms during testing. No changes need to be made, just saving in the designer.
If no save is performed between test alarm initiations, the first call does not go out. It appears that a retry will go out.
If I set the delay between messages duration to 0 seconds, the first call will always go out with no save between test alarm initiations. Obviously that won't work since all my roster members will get the call at once, which I do not want.
Text messaging via Airlink works regardless of saving between test alarms. I have a non-consolidated and consolidated SMS notification that work correctly in parallel.
Any guesses as to what might be causing my problem? I have tried completely deleting my alarm pipeline and recreating it, as deleting out voice notification profile and reentering with same configuration instantly solved voice call outs not going out yesterday.
Edit: as a follow up, this is a non-consolidated notification and it makes no difference whether I directly use a roster, or use an expression, same problem.
