Vtype in Pre-processing historical data
I can’t find information about Vtype column in my database table after I enabled Pre-processed Partitions in tag history.
Does anyone know about it? Please let me know more details.
Vtype
0
1
2
4
5
6
34
38
64
97
98
101
102
I found this from an old thread from Colby:
The vtype is used to indicate the role of the value, as well as the order for pre-processed windows. It is a bit flag value, so values can have multiple roles.
First off, 0 means that the value is the only value for the window. 1=min, 2=max, 4=last value in window, 32=“first” value (to order min and max), and 64=first value of window.
Thank you for your information jonathan.taylor.
I investigated my database and I found many values of vtype (0,1,2,4,5,6,34,38,64,97,98,101,102). Could you please give us more details about other numbers that aren’t mentioned in the Colby forum?
Thanks,
There are only those six values. The integer column represents a binary AND of the different values; for example, 102 means that the bits in position 64, 32, 4, and 2 are “on” - meaning that the flag for max, exit, first value, and entry are all set.
That’s clear, thank you PGriffith and Jonathan.taylor
