Hello
I use two DateTimeInput component’s. 1 shows only date and 2 shows time only.
I want to combine data and time and show this on label.
I do this but return type is a string not a date and time
concat(dateFormat({…/DateTimeInput.props.formattedValue},“YYYY-MM-dd”),dateFormat({…/DateTimeInput_0.props.formattedValue}," HH:mm"))
I also use
toDate(concat(dateFormat({…/DateTimeInput.props.formattedValue},“YYYY-MM-dd”),dateFormat({…/DateTimeInput_0.props.formattedValue}," HH:mm")))
but shows error
so can we return the date time parameter after combining two datetime components
with this I am attaching image
toDate(concat(dateFormat({../DateTimeInput.props.value},"YYYY-MM-dd"),dateFormat({../DateTimeInput_0.props.value}," HH:mm:ss")))
will get a date type
you can then (if you dont want the seconds) do a format to string again for the label dateFormat({../DateTimeInput_1.props.value},'YYYY-MM-dd HH:mm')
