i am making a login form in which my root container is a flex container.
- in root i have added two more flex containers
- in first flex container i have the text field
- in second flex container i have the password field
- i want to do is that when i press enter key in text field
- it will move to the password field
- both the components are in the same view
- but in different flex containers
Tip: Standard GUI is that Enter triggers the default button - probably the Login or similar in your view. (And Esc triggers the Cancel button.)
You should be aiming to move to next field with Tab.
I think you're looking for .focus(). I haven't had to do it so I can't help further at this time.
Use on onKeyPress event handler on the text field, and then .focus() on the password field:
"custom": {},
"params": {},
"props": {},
"root": {
"children": [
"events": {
"dom": {
"onKeyPress": {
"config": {
"script": "\tif event.key \u003d\u003d \u0027Enter\u0027:\n\t\tsystem.perspective.sendMessage(\u0027focus-pwd\u0027)"
"scope": "G",
"type": "script"
"meta": {
"name": "TextField"
"position": {
"basis": "32px"
"props": {
"placeholder": "Hit ENTER to..."
"type": "ia.input.text-field"
"meta": {
"name": "PasswordField"
"position": {
"basis": "32px"
"props": {
"placeholder": "...focus this field"
"scripts": {
"customMethods": [],
"extensionFunctions": null,
"messageHandlers": [
"messageType": "focus-pwd",
"pageScope": true,
"script": "\tself.focus()",
"sessionScope": false,
"viewScope": false
"type": "ia.input.password-field"
"meta": {
"name": "root"
"props": {
"direction": "column",
"style": {
"gap": 8,
"padding": 8
"type": "ia.container.flex"
You can paste that example into a new view by holding down SHIFT while right-clicking and selecting "Paste JSON." It uses a message to notify the password field rather than navigating to the field via getSibling() as that kind of code breaks as soon as you start renaming/reorganizing components (and should be easier to plug in to whatever layout you already have).
Just checking you're not trying to roll your own user login?
Thanks that .focus() solved the issue but i did it in a different way.
i just simply moved from that text field to the password field by writing in textField event action onKeyPressed script:
if event.key == "Enter":
self.parent.parent.getChild("FlexContainer_0").getChild("passwordField").focus()
my textField was in a flex container and the passwordField was in a different flex. both were in the same view.
i was making my own login but the problem has been solved
This sort of code breaks if you ever move components in and out of containers or rename them.
Consider using sendMessage() instead and adding a message handler on the target field to set focus on itself. This is a practice worth adopting and whoever has to maintain your code will appreciate it.
Also, please see Wiki - how to post code on this forum.
Seriously, what @Transistor said. It took me a while to get in the habit, but lately I'm soooo glad I did, as I've been able to revamp several different layouts without worrying about what I might have broke in the process. I now bind the value of every input to a custom view property, so I can reference that instead of the input itself. It not only safeguards it against layout changes, but makes for much cleaner, easier to understand code (I cringe every time I see a .getChild() or .getSibling()). Just a little extra effort in the short term can save you lots of hassle in the long run.
