Using Ignition 7.9.9. Came onto a project that has a window that has 10+ different containers underneath a root container. Each of these containers has a custom property “ReportData” with slightly different SQL Bindings, part of which has the Schema fed in as a parameter. As in
SELECT something
FROM {[client]Schema].table
etc
So what this means is usually all except the containers except the one relevant and shown to the user then throw a bunch of print statements to the console log that the SQL binding is faulty - usually an invalid object error (because the schemas don’t have the same design). There’s so much text that any print statements get lost. I am tasked with trying to clean this up. Is there a way to silence the warnings from these SQL bindings? To tell them not to print this issue to the console? Or a way to circumvent this with minimal changes?
