When you put them into the dataset, how did you control when the query would run?
I don’t mean to hijack your thread. I need help with this part that you do after though.
It’s just a root container dataset custom property that I have as a SQL Binding (not at the point where I converted everything to named queries yet). So “I” don’t decide when it runs at all. Polling is turned off, but once the window opens, Ignition at some point tells it to run, and then all the properties that rely on it get populated.
I don’t mind but if this does not yet answer your question, you may consider making a new thread for so future people can find things more easily.
