Hi guys,
I’m copying the whole folder from the bootcamp and rebuilding the dev environment on my computer but it fails at the very first step trying to build the Weather module (Module Bootcamp -Instroduction.pdf page 9). It’s saying that it couldn’t find the file “C:\DSOM\eclipse-jee-indigo-SR2-win32-x86_64\eclipse\workspace\Build\modules\WeatherModule-module-unsigned.modl” while I verify that the file does exist. The complete console output is below.
Any idea what might be wrong?
Thanks,
Hung.
Console output:
Buildfile: C:\DSOM\eclipse-jee-indigo-SR2-win32-x86_64\eclipse\workspace\Build\build-weather.xml
clean:
[delete] Deleting directory C:\DSOM\eclipse-jee-indigo-SR2-win32-x86_64\eclipse\workspace\Build\bin
[delete] Deleting directory C:\DSOM\eclipse-jee-indigo-SR2-win32-x86_64\eclipse\workspace\Build\modules
build:
[echo] WeatherModule 1.4.0.1-beta1
[echo] Build date: 09/03/2012 06:46 PM
[echo] Build version: 1
MakeProject:
[echo] Compiling WeatherModule_Client
[mkdir] Created dir: C:\DSOM\eclipse-jee-indigo-SR2-win32-x86_64\eclipse\workspace\Build\bin\WeatherModule_Client\bin
[javac] C:\DSOM\eclipse-jee-indigo-SR2-win32-x86_64\eclipse\workspace\Build\build.xml:41: warning: ‘includeantruntime’ was not set, defaulting to build.sysclasspath=last; set to false for repeatable builds
[javac] Compiling 10 source files to C:\DSOM\eclipse-jee-indigo-SR2-win32-x86_64\eclipse\workspace\Build\bin\WeatherModule_Client\bin
[javac] warning: [options] bootstrap class path not set in conjunction with -source 1.5
[javac] Note: C:\DSOM\eclipse-jee-indigo-SR2-win32-x86_64\eclipse\workspace\WeatherModule_Client\src\com\inductiveautomation\weather\client\ClientHook.java uses or overrides a deprecated API.
[javac] Note: Recompile with -Xlint:deprecation for details.
[javac] 1 warning
[copy] Copying 178 files to C:\DSOM\eclipse-jee-indigo-SR2-win32-x86_64\eclipse\workspace\Build\bin\WeatherModule_Client\bin
[mkdir] Created dir: C:\DSOM\eclipse-jee-indigo-SR2-win32-x86_64\eclipse\workspace\Build\bin\WeatherModule_Client\dist
[jar] Building jar: C:\DSOM\eclipse-jee-indigo-SR2-win32-x86_64\eclipse\workspace\Build\bin\WeatherModule_Client\dist\weather-client.jar
MakeProject:
[echo] Compiling WeatherModule_Designer
[mkdir] Created dir: C:\DSOM\eclipse-jee-indigo-SR2-win32-x86_64\eclipse\workspace\Build\bin\WeatherModule_Designer\bin
[javac] Compiling 3 source files to C:\DSOM\eclipse-jee-indigo-SR2-win32-x86_64\eclipse\workspace\Build\bin\WeatherModule_Designer\bin
[javac] Note: C:\DSOM\eclipse-jee-indigo-SR2-win32-x86_64\eclipse\workspace\WeatherModule_Designer\src\com\inductiveautomation\weather\designer\beaninfo\WeatherComponentBeanInfo.java uses or overrides a deprecated API.
[javac] 1 warning
[copy] Copying 2 files to C:\DSOM\eclipse-jee-indigo-SR2-win32-x86_64\eclipse\workspace\Build\bin\WeatherModule_Designer\bin
[mkdir] Created dir: C:\DSOM\eclipse-jee-indigo-SR2-win32-x86_64\eclipse\workspace\Build\bin\WeatherModule_Designer\dist
[jar] Building jar: C:\DSOM\eclipse-jee-indigo-SR2-win32-x86_64\eclipse\workspace\Build\bin\WeatherModule_Designer\dist\weather-designer.jar
MakeProject:
[echo] Compiling WeatherModule_Gateway
[mkdir] Created dir: C:\DSOM\eclipse-jee-indigo-SR2-win32-x86_64\eclipse\workspace\Build\bin\WeatherModule_Gateway\bin
[javac] Compiling 35 source files to C:\DSOM\eclipse-jee-indigo-SR2-win32-x86_64\eclipse\workspace\Build\bin\WeatherModule_Gateway\bin
[javac] warning: [options] bootstrap class path not set in conjunction with -source 1.6
[javac] Note: Some input files use unchecked or unsafe operations.
[javac] Note: Recompile with -Xlint:unchecked for details.
[javac] 1 warning
[copy] Copying 3 files to C:\DSOM\eclipse-jee-indigo-SR2-win32-x86_64\eclipse\workspace\Build\bin\WeatherModule_Gateway\bin
MakeProject-ReplaceProps:
[echo] WeatherGateway.properties:Meta.ReleaseDate=09/03/2012 06:46 PM
[propertyfile] Creating new property file: C:\DSOM\eclipse-jee-indigo-SR2-win32-x86_64\eclipse\workspace\Build\bin\WeatherModule_Gateway\bin\WeatherGateway.properties
[echo] WeatherGateway.properties:Meta.Version=1
[propertyfile] Updating property file: C:\DSOM\eclipse-jee-indigo-SR2-win32-x86_64\eclipse\workspace\Build\bin\WeatherModule_Gateway\bin\WeatherGateway.properties
[mkdir] Created dir: C:\DSOM\eclipse-jee-indigo-SR2-win32-x86_64\eclipse\workspace\Build\bin\WeatherModule_Gateway\dist
[jar] Building jar: C:\DSOM\eclipse-jee-indigo-SR2-win32-x86_64\eclipse\workspace\Build\bin\WeatherModule_Gateway\dist\weather-gateway.jar
[echo] Making WeatherModule modl
[mkdir] Created dir: C:\DSOM\eclipse-jee-indigo-SR2-win32-x86_64\eclipse\workspace\Build\temp_modl
[mkdir] Created dir: C:\DSOM\eclipse-jee-indigo-SR2-win32-x86_64\eclipse\workspace\Build\modules
[copy] Copying 1 file to C:\DSOM\eclipse-jee-indigo-SR2-win32-x86_64\eclipse\workspace\Build\temp_modl
[pack200] Building: C:\DSOM\eclipse-jee-indigo-SR2-win32-x86_64\eclipse\workspace\Build\temp_modl\weather-designer.jar.pack.gz
[pack200] Packing with Pack200
[pack200] Source File :C:\DSOM\eclipse-jee-indigo-SR2-win32-x86_64\eclipse\workspace\Build\bin\WeatherModule_Designer\dist\weather-designer.jar
[pack200] Dest. File :C:\DSOM\eclipse-jee-indigo-SR2-win32-x86_64\eclipse\workspace\Build\temp_modl\weather-designer.jar.pack.gz
[pack200] Config file :C:\DSOM\eclipse-jee-indigo-SR2-win32-x86_64\eclipse\workspace\Build\pack200.properties
[pack200] Building: C:\DSOM\eclipse-jee-indigo-SR2-win32-x86_64\eclipse\workspace\Build\temp_modl\commons-math3-3.0.jar.pack.gz
[pack200] Source File :C:\DSOM\eclipse-jee-indigo-SR2-win32-x86_64\eclipse\workspace\WeatherModule_Designer\lib\commons-math3-3.0.jar
[pack200] Dest. File :C:\DSOM\eclipse-jee-indigo-SR2-win32-x86_64\eclipse\workspace\Build\temp_modl\commons-math3-3.0.jar.pack.gz
[pack200] Building: C:\DSOM\eclipse-jee-indigo-SR2-win32-x86_64\eclipse\workspace\Build\temp_modl\weather-client.jar.pack.gz
[pack200] Source File :C:\DSOM\eclipse-jee-indigo-SR2-win32-x86_64\eclipse\workspace\Build\bin\WeatherModule_Client\dist\weather-client.jar
[pack200] Dest. File :C:\DSOM\eclipse-jee-indigo-SR2-win32-x86_64\eclipse\workspace\Build\temp_modl\weather-client.jar.pack.gz
[zip] Building zip: C:\DSOM\eclipse-jee-indigo-SR2-win32-x86_64\eclipse\workspace\Build\modules\WeatherModule-module-unsigned.modl
[delete] Deleting directory C:\DSOM\eclipse-jee-indigo-SR2-win32-x86_64\eclipse\workspace\Build\temp_modl
deploy:
[echo] Installing WeatherModule on Ignition Gateway.
[postmodule] moduleFile=C:\DSOM\eclipse-jee-indigo-SR2-win32-x86_64\eclipse\workspace\Build\modules\WeatherModule-module-unsigned.modl, postUrl=http://localhost:8088/main/system/DeveloperModuleLoadingServlet
BUILD FAILED
C:\DSOM\eclipse-jee-indigo-SR2-win32-x86_64\eclipse\workspace\Build\build-weather.xml:118: java.io.FileNotFoundException: localhost:8088/main/system/Devel … ingServlet
Total time: 16 seconds
