How do you go about getting the weatherbug API?
You probably want an Weatherbug API key, which you can get from here: http://developer.weatherbug.com/ They typically send you a key via email within 24 hours.
Tried the API they gave and all the tags come back as stale.
Can you PM me the key that you got from WeatherBug? I tried mine, and my tags are able to pull in weather data.
So, apparently there are TWO different ways to get a WeatherBug API key
The link that you want to use to sign up is here. This will send a key in AXXXXXXXXX format, which is what the Weather module requires. The site that you DON’T want is api-portal.earthnetworks.com. This site gives you a consumer key and a secret key, which don’t work with the Weather module.
