WeatherModule 1.0.0-beta1 (b1) installed OK
when adding Devices, added device does not show on the Devices list until restart Gateway.
then WeatherModule failed to start with errors
delete added Device and restart WeatherModule: no error.
java.lang.Exception: Exception while starting up module “weather”.
com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl$LoadedModule.startup(ModuleManagerImpl.java:1761)
com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl.startupModule(ModuleManagerImpl.java:1172)
com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl$5.call(ModuleManagerImpl.java:863)
com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl.executeModuleOperation(ModuleManagerImpl.java:898)
com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl.restartModuleInternal(ModuleManagerImpl.java:849)
com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl.access$1400(ModuleManagerImpl.java:100)
com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl$RestartCommand.execute(ModuleManagerImpl.java:1442)
com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl$Receiver.receiveCall(ModuleManagerImpl.java:1404)
com.inductiveautomation.ignition.gateway.cluster.QueueableMessageReceiver.receiveCall(QueueableMessageReceiver.java:45)
com.inductiveautomation.ignition.gateway.redundancy.RedundancyManagerImpl.dispatchMessage(RedundancyManagerImpl.java:472)
com.inductiveautomation.ignition.gateway.redundancy.RedundancyManagerImpl$ExecuteTask.run(RedundancyManagerImpl.java:493)
com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$ThrowableCatchingRunnable.run(BasicExecutionEngine.java:520)
java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source)
java.util.concurrent.FutureTask.run(Unknown Source)
java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(Unknown Source)
java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
java.lang.Thread.run(Unknown Source)
java.lang.NoClassDefFoundError: com/inductiveautomation/xopc/common/types/DataValue
com.inductiveautomation.weather.driver.DataNode.(DataNode.java:18)
com.inductiveautomation.weather.driver.WeatherDriver.addCurrentNodes(WeatherDriver.java:74)
com.inductiveautomation.weather.driver.WeatherDriver.initialize(WeatherDriver.java:54)
com.inductiveautomation.xopc.driver.common.nodemap.NodeMapDriver.initializeInternal(NodeMapDriver.java:60)
com.inductiveautomation.xopc.driver.api.AbstractDriver2.initialize(AbstractDriver2.java:89)
com.inductiveautomation.xopc.server.devices.AbstractDevice.initialize(AbstractDevice.java:83)
com.inductiveautomation.xopc.server.devices.DeviceManager.handleRegisterDriver(DeviceManager.java:422)
com.inductiveautomation.xopc.server.devices.DeviceManager.registerDriver(DeviceManager.java:334)
com.inductiveautomation.xopc.driver.common.AbstractDriverModuleHook.serviceReady(AbstractDriverModuleHook.java:76)
com.inductiveautomation.ignition.gateway.services.ModuleServicesManagerImpl.subscribe(ModuleServicesManagerImpl.java:90)
com.inductiveautomation.xopc.driver.common.AbstractDriverModuleHook.startup(AbstractDriverModuleHook.java:50)
com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl$LoadedModule.startup(ModuleManagerImpl.java:1751)
java.lang.ClassNotFoundException: com.inductiveautomation.xopc.common.types.DataValue
java.net.URLClassLoader$1.run(Unknown Source)
java.security.AccessController.doPrivileged(Native Method)
java.net.URLClassLoader.findClass(Unknown Source)
java.lang.ClassLoader.loadClass(Unknown Source)
