Web Browser component not working on mobile launch
When I download and launch the project as a client everything works fine, but when I launch the project from a web browser with the mobile launch link the web browser component and the rest of the components in the window wont even show.
This are the errors the console gives me. I really some of you can help with this, and thank you.
Some potentially important info is missing from the screenshots, can you post the raw text of those errors and also include information about the gateway and device you are trying to launch on? (OS, versions, etc)
I’m having the same issue. What info are you looking to get?
I’m unable to resize the same window or select the text and paste into this post.
Ignition Server is running on Windows 10 and Ignition v7.9.4
Mobile Client is running on a raspberry Pi3, Raspbian
I do see an error that says:
Exception in thread “AWT-EventQueue-0” java.lang.ExceptionInInitalizerError
blah
blah
Caused by: java.lang.RuntimeException: java.io.FileNotFoundException: C:\WINDOWS\system32\config\systemprofile\AppData\Local\JXBrowser\jxbrowser-chromium-55.0.2883.87.6.14.2\jxbrowser-common64.dll
(The system cannot find the file specified)
Does my Ignition Server need this file? I found the path and indeed the file is not there.
Where would I get this file from?
Any help would be great!
