Hi, I have managed to loose access to Web Config page, it is reporting Unauthorized Access, I am using the default account setup on install. Is there anyway of getting around this? Or will it require an uninstall of the system?
The “gwcmd” command line tool can reset your admin password and identity provider.
Thanks for this, do i need to just run the batch file, or add anything to the command to reset identity provider. Password is ok, as it lets me login in, but does not let me access this config page.
I haven’t needed it in a long time… (~v7.7?) Docs:
https://docs.inductiveautomation.com/display/DOC81/Gateway+Command-line+Utility+-+gwcmd
Many Thanks, that worked a treat.
