Web dev module limit
We would like to use ignition gateway with web dev module to be the backend but to use react or other platform as frontend.
Let's say, if there are 20k tags per project, the front end view of 1 sec refresh rate, and there are 10 projects. Is it possible to achieve using this setup?
Is there any datasheet about the web dev api limit?
There's no API limit. You'll just need to test your hardware with that workload, same as always with Ignition.
