Web Developer Module.modl feedback
Hello,
Would like to know if the Web Developer Module is stable and work well in a Igntion perspective project.
Adding this module may cause trouble to my current project?
I would like to add some speacial grid with column pin capacibiities and would like to know if this is a good aproach to it.
If is stable I can add some complex UI components this way?
Cheers
The web developer module will not cause trouble. (Where did you get this idea?)
But it will likely not serve your purpose, as its resources are not integrated with Perspective at all. It can supply content for IFrames, or for Audio/Video components, but there's no native, supported way for you supply javascript to Perspective through WebDev.
You should look at @bmusson's Embr modules.
Also, if want to try Periscope’s Client Resource feature, send me a DM (it’s on track but currently unreleased)
It allows you author React components directly in the designer, and use those components in Perspective.
