Hello, I'm wanting to add beautifulsoup 3.2.2 on ignition 7.9 but ignition wont add it when i do file>import any help would be great, thanks
BeautifulSoup3.2.2.zip (22.0 KB)
If it's the one from this post (and looking at the file, I believe it is), then this was put together for 8.x
You can try unzipping it, then copying the contents of code.py into a blank script.
Open it in notepad and copy everything into a script? And where would I do the parsing, in the same script?
Yes to both. ![]()
i did then i opened script console and put this in
from BeautifulSoup import BeautifulSoup
url = "http://192.168.140.31/15"
soup = BeautifulSoup(system.net.httpGet(url))
t = soup.find('table')
tr = t.findAll('tr')
headers = ['meter', 'value']
data =
for row in tr:
td = row.findAll('td')
if len(td) > 0:
data.append([col.text for col in td])
dataOut = system.dataset.toDataSet(headers, data)
but got the following error
"eback (most recent call last):
File "", line 1, in
ImportError: No module named BeautifulSoup"
Please edit your post, select the code block, and press the </> button to format it as code. This will preserve indentation and apply syntax highlighting.
- Show us where you put it. This will affect where your import happens.
- You're not going to get anything from my power meter. It doesn't go to the internet.
im also assuming i need to put this in gateway startup scripts
from NewScript import BeautifulSoup
Or, rename NewScript...
Also I see an error marker at the bottom. There might be something in the copy/paste that didn't come through.
I renamed and published but i still get and also went back to the original name
File "", line 1, in
ImportError: No module named NewScript
Edit: also got rid of the red error line.
Ok, had to spin up a 7.9 VM...
Here's one that will import into 7.9
BeautifulSoup_3.3.2.proj (29.8 KB)
Be sure to save after importing.
from project.BeautifulSoup import BeautifulSoup
or, if you import it into the global scripts:
from shared.BeautifulSoup import BeautifulSoup
apologies but im getting this error. im running 7.9.4
actually i just changed the rev in the notepad and it imported hopefully it will work i appreciate all the help
We always recommend upgrading to the latest version. (7.9.21) ![]()
i dont think i can do this ive tried for the past 16 hours and i cant parse a single html text but beautiful soup works
at least i think it does.
What's the issue ?
im trying to scrap the cfs data on this website MERCED R NR BRICEBURG #2 (MBG)
but i just dont know how to write it. i can get the html but idk how to parse it. all the examples online don't really help bc the commands dont work. i was also assuming i need to download pip.
I can't even open that page ;D
edit: I have some free time (but not a lot), so if you want help parsing html, I'll be there for a little while.
