This post is using an assumption that Perspective Workstation and Vision WebBrowser module support a JxBrowser version that supports Webauthn. On a side note, is there a release tree that lists what version of JxBrowser/Chromium is associated with different Ignition versions?
Since custom Javascript isn’t available in Perspective, can a custom module be created that exposes code that would trigger the Webauthn support built into JxBrowser/Chromium?
