Hi all,
Wondering if there is a way to enable caching and/or Gzip compression for REST Webdev calls? I would think that those are enabled at the Web Server level, but do we have access to those settings?
Thanks,
Oscar.
Hi all,
Thanks,
Oscar.
Adding more details here after some research:
It looks like on the later versions of Jetty, gzip compression is enabled via gzip.mod, and enabled via the jetty-gzip.xml or a “context xml” file. Not sure where those reside?
https://www.eclipse.org/jetty/documentation/9.3.22.v20171030/gzip-filter.html
In earlier versions, a gzip handler can be added to web.xml (/ignition/webserver/webapps/main/WEB-INF/web.xml); but that approach is no longer supported? Can someone confirm?
Bumping this up to see if anyone has any input. (and shamelessly tagging those who may have input
)@Kevin.McClusky, @Travis.Cox, @Colby.Clegg
Thanks!
