WebDev error in script (Show Report in url)
Hi, I want to create a WebDev script python but It don't show me the report that I had create, I tried it with this url http://10.10.100.103:8088/system/webdev/Mantenimiento_vn/Recursos/Preventivo_E but show me this error Error: No visible constructors for class (javax.servlet.http.HttpServletResponse) some one can help me pls I want to show the pdf in a http link http://10.10.100.103:8088/system/webdev/Mantenimiento_vn/Recursos/Preventivo_E please ,the report has the two parameters and it is the url of the report. Thanks a lot.
def doGet(request, session):
    logger = system.util.getLogger("myLogger")
    logger.info("Iniciando la ejecución de doGet")
    path = "RENEW/PLANILLAS/PREVENTIVA_PLANILLA/PLANILLA_MANT_PREVENTIVO_E"
    params = {
        "ID_PREVENTIVA": 6228,
        "CATEGORIA": "INFRAESTRUCTURA NECESARIA"
    try:
        report_bytes = system.report.executeReport(
            path=path,
            project='Mantenimiento_vn',
            parameters=params,
            fileType='pdf'
        # Alternativa para versiones sin system.webdev
        from javax.servlet.http import HttpServletResponse
        response = HttpServletResponse()
        response.setContentType("application/pdf")
        response.setHeader("Content-Disposition", "inline; filename=preventivo_e.pdf")
        response.getOutputStream().write(report_bytes)
        response.getOutputStream().flush()
        return response
    except Exception as e:
        logger.error("Error: " + str(e))
        return "Error al generar el reporte: " + str(e)
I solved using this code:
 params = {
 try:
         path=path,
         parameters=params,
         fileType='pdf'
    return {
        "contentType": "application/pdf",
         "headers": {
             "Content-Disposition": "inline; filename=preventivo_e.pdf"
         "bytes": report_bytes
     logger.error("Error al generar el reporte: " + str(e))
     return {"error": "Error al generar el reporte: " + str(e)}
