WebDev not available in Designer, for Edge Panel license
I've installed Ignition Edge Panel, but I can't find WebDev in my designer.
Am I missing something obvious ?
Best regards
V
Check the installed Modules, you might have licensed it, but possible you've not installed the actual module
Also, what version? As there were significant license changes for Edge as of 8.1.34, you should be working with 8.1.35 or higher (8.1.34 was pulled due to a regression).
Thanks, wasn not aware that it wasn't included in the base install.
