WebDev - Security Zones
I'm on 8.1.41
Is there a way to use Security Zones in WebDev module ?
I want to secured some WebDev scripts to give access to specific IP addresses without authentification required.
I don't want to hardcode allowed ip addresses in my scripts, I want to be able to configure it in the gateway...
Not in convenient built in way, but if you have a GatewayContext there's nothing stopping you from grabbing the SecurityZoneManager and doing something with it, like call getZonesFor() with some IdentityTraits you built using the IP address from the request header.
Something like this?
gateway = request["context"]
listOfZones = gateway.SecurityZoneManager.getZonesFor(request["remoteAddr"])
Almost, but getZonesFor requires you build an IdentityTraits object.
Not familiar with that, have you some examples for me ?
You should be able to figure this out from looking at the Javadoc, it's a necessary skill if you will be using classes from the SDK.
It would look something like this:
from com.inductiveautomation.ignition.gateway.authentication.securityzones import IdentityTraits
id = IdentityTraits.newBuilder.ipAddress(request["remoteAddr"]).build()
Another thing to keep in mind here is that the usefulness/accuracy of the remote address as seen by the WebDev module will depend entirely on your network architecture.
Seems that something going wrong with the IdentityTraits
The first part of my code working well and retun list of securityzones
szm = gateway.getSecurityZoneManager()
listOfZones = szm.getZones()
return {'json': {"Zones for {}:".format(request["remoteAddr"]): listOfZones}}
But when I try to build the IdentityTraits I got server error
com.inductiveautomation.ignition.common.script.JythonExecException: Traceback (most recent call last): File "", line 8, in doGet AttributeError: 'reflectedfunction' object has no attribute 'ipAddress'
identity = IdentityTraits.newBuilder.ipAddress(request["remoteAddr"]).build()
return {'html': "Here !!!"}
Was missing () for newBuilder
identity = IdentityTraits.newBuilder().ipAddress(request["remoteAddr"]).build()
szm.getZonesFor(identity) always return empty list
	identityZones = szm.getZonesFor(identity)
	return {'json':
					"Zones for {}: ".format(identity.getIpAddress()): identityZones,
					"Zones for context: " : listOfZones
In the Gateway, set the logger for "Security.SecurityZones.Zone" to DEBUG level and then send the request again and see what gets logged.
Zone 'WebDev_API' does not match due to incorrect value for qualifier 'direct-connection'. Remote machine sent: '{ip-address=10.7.15.64}'
Ok, I think you need to set some additional attributes on the IdentityTraits you build.
Probably call isDirect(true) and gatewayScope(): IdentityTraits.Builder
missing isDirect, isSecure and gatewayScopre()
identity = IdentityTraits.newBuilder().ipAddress(request["remoteAddr"]).isDirect(True).isSecure(False).gatewayScope().build()
