I'm currently going through the Kanoa Ops self-directed training (custom MES module/projects), and one of the sections has me using the WebDev module. But it's not enabled in the gateway, which I assume is why it doesn't show up in the designer. I tried manually enabling it, got a generic error. I tried downloading the module from Inductive's site and installing it again, and after gateway restart it still didn't enable. And I can't uninstall it either. I am using an admin login. Is there anything I'm missing?
Can you look in the gateway logs to see full details of any error message(s), and possibly also post some screenshots of what you're seeing on the module configuration page?
Im assuming you're using the Kanoa docker template, there was an issue in the docker-compose file. In the GATEWAY_MODULES_ENABLED section I had originally used com.inductiveautomation.web-developer when it should have been com.inductiveautomation.webdev. If you change that line and re-compose up your gateway it will become enabled.
