I am creating a module that will have webpage configuration, so have been building one based off of the example on git. However, when I upgrade the module I am getting the error of “error stopping module” looking through the logs, it seems to begin here in the code
at com.inductiveautomation.ignition.examples.hce.GatewayHook.shutdown(GatewayHook.java:201)
ultimately throwing this exception
java.lang.IllegalArgumentException: Argument 'requestCycle' may not be null.
I have tested by building the example webpage module and get the same results.
Any ideas?
heres the entire trace for reference
at org.apache.wicket.util.lang.Args.notNull(Args.java:41)
at org.apache.wicket.Application.fetchCreateAndSetSession(Application.java:1552)
at org.apache.wicket.Session.get(Session.java:152)
at org.apache.wicket.RestartResponseAtInterceptPageException$InterceptData.get(RestartResponseAtInterceptPageException.java:146)
at org.apache.wicket.RestartResponseAtInterceptPageException$1.matchedData(RestartResponseAtInterceptPageException.java:211)
at org.apache.wicket.RestartResponseAtInterceptPageException$1.getCompatibilityScore(RestartResponseAtInterceptPageException.java:179)
at org.apache.wicket.request.mapper.CompoundRequestMapper.mapRequest(CompoundRequestMapper.java:134)
at org.apache.wicket.protocol.https.HttpsMapper.mapRequest(HttpsMapper.java:92)
at org.apache.wicket.request.mapper.CompoundRequestMapper.unmount(CompoundRequestMapper.java:209)
at org.apache.wicket.protocol.http.WebApplication.unmount(WebApplication.java:387)
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl$LoadedModule.shutdown(ModuleManagerImpl.java:2525)
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl$3.call(ModuleManagerImpl.java:784)
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl.executeModuleOperation(ModuleManagerImpl.java:905)
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl.uninstallModuleInternal(ModuleManagerImpl.java:776)
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl$UninstallCommand.execute(ModuleManagerImpl.java:1828)
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl$Receiver.receiveCall(ModuleManagerImpl.java:1801)
at com.inductiveautomation.ignition.gateway.redundancy.QueueableMessageReceiver.receiveCall(QueueableMessageReceiver.java:47)
at com.inductiveautomation.ignition.gateway.redundancy.RedundancyManagerImpl.dispatchMessage(RedundancyManagerImpl.java:813)
at com.inductiveautomation.ignition.gateway.redundancy.RedundancyManagerImpl$ExecuteTask.run(RedundancyManagerImpl.java:849)
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$ThrowableCatchingRunnable.run(BasicExecutionEngine.java:518)
any pointers would be appreciated, all I have found so far online seems to point to threads not finishing in time
