I have Ignition 7.9.16 running on Windows 10 IOT. One of my instances which was working now won’t load. The Webserver shows as started but the Gateway is continuously loading. I have many “Uncaught exception during getContectState()”. Has anyone seen an issue like this before or have any suggestions? Any help would be appreciated.
wrapper.log (81.3 KB)
STATUS | wrapper | 2022/02/09 15:25:56 | → Wrapper Started as Service
STATUS | wrapper | 2022/02/09 15:25:57 | Java Service Wrapper Standard Edition 64-bit 3.5.35
STATUS | wrapper | 2022/02/09 15:25:57 | Copyright (C) 1999-2018 Tanuki Software, Ltd. All Rights Reserved.
STATUS | wrapper | 2022/02/09 15:25:57 | http://wrapper.tanukisoftware.com
STATUS | wrapper | 2022/02/09 15:25:57 | Licensed to Inductive Automation for Inductive Automation
STATUS | wrapper | 2022/02/09 15:25:58 | Launching a JVM…
INFO | jvm 1 | 2022/02/09 15:25:59 | WrapperManager: Initializing…
INFO | jvm 1 | 2022/02/09 15:26:01 | 15:26:01,354 |-INFO in ch.qos.logback.classic.LoggerContext[default] - Found resource [data\logback.xml] at [file:/C:/Program%20Files/Inductive%20Automation/Ignition/data/logback.xml]
INFO | jvm 1 | 2022/02/09 15:26:01 | 15:26:01,668 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [ch.qos.logback.core.ConsoleAppender]
INFO | jvm 1 | 2022/02/09 15:26:01 | 15:26:01,690 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [SysoutAppender]
INFO | jvm 1 | 2022/02/09 15:26:01 | 15:26:01,723 |-INFO in ch.qos.logback.core.joran.action.NestedComplexPropertyIA - Assuming default type [ch.qos.logback.classic.encoder.PatternLayoutEncoder] for [encoder] property
INFO | jvm 1 | 2022/02/09 15:26:02 | 15:26:01,908 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [com.inductiveautomation.logging.SQLiteAppender]
INFO | jvm 1 | 2022/02/09 15:26:02 | 15:26:01,939 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [DB]
INFO | jvm 1 | 2022/02/09 15:26:04 | 15:26:04,328 |-INFO in ch.qos.logback.core.db.DataSourceConnectionSource@24eab104 - Driver name=SQLite JDBC
INFO | jvm 1 | 2022/02/09 15:26:04 | 15:26:04,330 |-INFO in ch.qos.logback.core.db.DataSourceConnectionSource@24eab104 - Driver version=3.23.1
INFO | jvm 1 | 2022/02/09 15:26:04 | 15:26:04,330 |-INFO in ch.qos.logback.core.db.DataSourceConnectionSource@24eab104 - supportsGetGeneratedKeys=true
INFO | jvm 1 | 2022/02/09 15:26:04 | 15:26:04,392 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [ch.qos.logback.classic.AsyncAppender]
INFO | jvm 1 | 2022/02/09 15:26:04 | 15:26:04,405 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [SysoutAsync]
INFO | jvm 1 | 2022/02/09 15:26:04 | 15:26:04,406 |-INFO in ch.qos.logback.core.joran.action.AppenderRefAction - Attaching appender named [SysoutAppender] to ch.qos.logback.classic.AsyncAppender[SysoutAsync]
INFO | jvm 1 | 2022/02/09 15:26:04 | 15:26:04,406 |-INFO in ch.qos.logback.classic.AsyncAppender[SysoutAsync] - Attaching appender named [SysoutAppender] to AsyncAppender.
INFO | jvm 1 | 2022/02/09 15:26:04 | 15:26:04,409 |-INFO in ch.qos.logback.classic.AsyncAppender[SysoutAsync] - Setting discardingThreshold to 51
INFO | jvm 1 | 2022/02/09 15:26:04 | 15:26:04,412 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [ch.qos.logback.classic.AsyncAppender]
INFO | jvm 1 | 2022/02/09 15:26:04 | 15:26:04,413 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [DBAsync]
INFO | jvm 1 | 2022/02/09 15:26:04 | 15:26:04,414 |-INFO in ch.qos.logback.core.joran.action.AppenderRefAction - Attaching appender named [DB] to ch.qos.logback.classic.AsyncAppender[DBAsync]
INFO | jvm 1 | 2022/02/09 15:26:04 | 15:26:04,414 |-INFO in ch.qos.logback.classic.AsyncAppender[DBAsync] - Attaching appender named [DB] to AsyncAppender.
INFO | jvm 1 | 2022/02/09 15:26:04 | 15:26:04,414 |-INFO in ch.qos.logback.classic.AsyncAppender[DBAsync] - Setting discardingThreshold to 51
INFO | jvm 1 | 2022/02/09 15:26:04 | 15:26:04,425 |-INFO in ch.qos.logback.classic.joran.action.RootLoggerAction - Setting level of ROOT logger to INFO
INFO | jvm 1 | 2022/02/09 15:26:04 | 15:26:04,426 |-INFO in ch.qos.logback.core.joran.action.AppenderRefAction - Attaching appender named [SysoutAsync] to Logger[ROOT]
INFO | jvm 1 | 2022/02/09 15:26:04 | 15:26:04,429 |-INFO in ch.qos.logback.core.joran.action.AppenderRefAction - Attaching appender named [DBAsync] to Logger[ROOT]
INFO | jvm 1 | 2022/02/09 15:26:04 | 15:26:04,430 |-INFO in ch.qos.logback.classic.joran.action.ConfigurationAction - End of configuration.
INFO | jvm 1 | 2022/02/09 15:26:04 | 15:26:04,437 |-INFO in ch.qos.logback.classic.joran.JoranConfigurator@56d3f206 - Registering current configuration as safe fallback point
INFO | jvm 1 | 2022/02/09 15:26:04 | I [o.e.j.u.log ] [21:26:04]: Logging initialized @5653ms to org.eclipse.jetty.util.log.Slf4jLog
INFO | jvm 1 | 2022/02/09 15:26:05 | [Catapult] [1644441965130]: Uncaught exception during getContextState():
INFO | jvm 1 | 2022/02/09 15:26:05 | java.lang.NullPointerException
INFO | jvm 1 | 2022/02/09 15:26:05 | at com.inductiveautomation.catapult.Catapult.getSRContext(Catapult.java:208)
INFO | jvm 1 | 2022/02/09 15:26:05 | at com.inductiveautomation.catapult.Catapult.access$800(Catapult.java:56)
INFO | jvm 1 | 2022/02/09 15:26:05 | at com.inductiveautomation.catapult.Catapult$CatapultRequestReceiverImpl.getContextState(Catapult.java:294)
INFO | jvm 1 | 2022/02/09 15:26:05 | at com.inductiveautomation.catapult.Catapult$CatapultRequestReceiverImpl.requestReceieved(Catapult.java:731)
INFO | jvm 1 | 2022/02/09 15:26:05 | at com.inductiveautomation.catapult.CatapultRequestServer.handleRequest(CatapultRequestServer.java:60)
INFO | jvm 1 | 2022/02/09 15:26:05 | at com.inductiveautomation.catapult.CatapultRequestServer.access$100(CatapultRequestServer.java:27)
INFO | jvm 1 | 2022/02/09 15:26:05 | at com.inductiveautomation.catapult.CatapultRequestServer$RequestFileMonitor$2.run(CatapultRequestServer.java:118)
INFO | jvm 1 | 2022/02/09 15:26:05 | at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
INFO | jvm 1 | 2022/02/09 15:26:05 | at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
INFO | jvm 1 | 2022/02/09 15:26:05 | at java.lang.Thread.run(Unknown Source)
INFO | jvm 1 | 2022/02/09 15:26:05 | I [Jetpad ] [21:26:05]: Existing keystore found at C:\Program Files\Inductive Automation\Ignition\webserver\ssl.key
INFO | jvm 1 | 2022/02/09 15:26:06 | I [o.e.j.s.Server ] [21:26:06]: jetty-9.4.24.v20191120; built: 2019-11-20T21:37:49.771Z; git: 363d5f2df3a8a28de40604320230664b9c793c16; jvm 1.8.0_241-b07
INFO | jvm 1 | 2022/02/09 15:26:08 | I [o.e.j.w.StandardDescriptorProcessor] [21:26:08]: NO JSP Support for /main, did not find org.apache.jasper.servlet.JspServlet
INFO | jvm 1 | 2022/02/09 15:26:08 | I [o.e.j.s.session ] [21:26:08]: DefaultSessionIdManager workerName=node0
INFO | jvm 1 | 2022/02/09 15:26:08 | I [o.e.j.s.session ] [21:26:08]: No SessionScavenger set, using defaults
INFO | jvm 1 | 2022/02/09 15:26:09 | I [o.e.j.s.session ] [21:26:08]: node0 Scavenging every 600000ms
INFO | jvm 1 | 2022/02/09 15:26:09 | I [o.e.j.u.TypeUtil ] [21:26:09]: JVM Runtime does not support Modules
INFO | jvm 1 | 2022/02/09 15:26:09 | W [o.e.j.w.WebAppContext ] [21:26:09]: Failed startup of context o.e.j.w.WebAppContext@6ce0ce08{Ignition,/main,file:///C:/Program%20Files/Inductive%20Automation/Ignition/webserver/webapps/main/,UNAVAILABLE}
INFO | jvm 1 | 2022/02/09 15:26:09 | javax.servlet.ServletException: Unable to start up context. Context temp folder “temp” does not exist.
INFO | jvm 1 | 2022/02/09 15:26:09 | at com.inductiveautomation.ignition.gateway.bootstrap.SRFilter.init(SRFilter.java:50)
INFO | jvm 1 | 2022/02/09 15:26:09 | at org.apache.wicket.protocol.http.WicketFilter.init(WicketFilter.java:314)
INFO | jvm 1 | 2022/02/09 15:26:09 | at org.eclipse.jetty.servlet.FilterHolder.initialize(FilterHolder.java:134)
INFO | jvm 1 | 2022/02/09 15:26:09 | at org.eclipse.jetty.servlet.ServletHandler.lambda$initialize$0(ServletHandler.java:751)
INFO | jvm 1 | 2022/02/09 15:26:09 | at java.util.Spliterators$ArraySpliterator.forEachRemaining(Unknown Source)
INFO | jvm 1 | 2022/02/09 15:26:09 | at java.util.stream.Streams$ConcatSpliterator.forEachRemaining(Unknown Source)
INFO | jvm 1 | 2022/02/09 15:26:09 | at java.util.stream.ReferencePipeline$Head.forEach(Unknown Source)
INFO | jvm 1 | 2022/02/09 15:26:09 | at org.eclipse.jetty.servlet.ServletHandler.initialize(ServletHandler.java:744)
INFO | jvm 1 | 2022/02/09 15:26:09 | at org.eclipse.jetty.servlet.ServletContextHandler.startContext(ServletContextHandler.java:360)
INFO | jvm 1 | 2022/02/09 15:26:09 | at org.eclipse.jetty.webapp.WebAppContext.startWebapp(WebAppContext.java:1445)
INFO | jvm 1 | 2022/02/09 15:26:09 | at org.eclipse.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1409)
INFO | jvm 1 | 2022/02/09 15:26:09 | at org.eclipse.jetty.server.handler.ContextHandler.doStart(ContextHandler.java:822)
INFO | jvm 1 | 2022/02/09 15:26:09 | at org.eclipse.jetty.servlet.ServletContextHandler.doStart(ServletContextHandler.java:275)
INFO | jvm 1 | 2022/02/09 15:26:09 | at org.eclipse.jetty.webapp.WebAppContext.doStart(WebAppContext.java:524)
INFO | jvm 1 | 2022/02/09 15:26:09 | at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:72)
INFO | jvm 1 | 2022/02/09 15:26:09 | at org.eclipse.jetty.util.component.ContainerLifeCycle.start(ContainerLifeCycle.java:169)
INFO | jvm 1 | 2022/02/09 15:26:09 | at org.eclipse.jetty.util.component.ContainerLifeCycle.doStart(ContainerLifeCycle.java:117)
INFO | jvm 1 | 2022/02/09 15:26:09 | at org.eclipse.jetty.server.handler.AbstractHandler.doStart(AbstractHandler.java:100)
INFO | jvm 1 | 2022/02/09 15:26:09 | at org.eclipse.jetty.server.Server.start(Server.java:407)
INFO | jvm 1 | 2022/02/09 15:26:09 | at org.eclipse.jetty.util.component.ContainerLifeCycle.doStart(ContainerLifeCycle.java:110)
INFO | jvm 1 | 2022/02/09 15:26:09 | at org.eclipse.jetty.server.Server.doStart(Server.java:371)
INFO | jvm 1 | 2022/02/09 15:26:09 | at com.inductiveautomation.catapult.Jetpad.start(Jetpad.java:414)
INFO | jvm 1 | 2022/02/09 15:26:09 | at com.inductiveautomation.catapult.Catapult.start(Catapult.java:138)
INFO | jvm 1 | 2022/02/09 15:26:09 | at com.inductiveautomation.catapult.Catapult.main(Catapult.java:63)
INFO | jvm 1 | 2022/02/09 15:26:09 | at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
INFO | jvm 1 | 2022/02/09 15:26:09 | at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
INFO | jvm 1 | 2022/02/09 15:26:09 | at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
INFO | jvm 1 | 2022/02/09 15:26:09 | at java.lang.reflect.Method.invoke(Unknown Source)
INFO | jvm 1 | 2022/02/09 15:26:09 | at org.tanukisoftware.wrapper.WrapperSimpleApp.run(WrapperSimpleApp.java:349)
INFO | jvm 1 | 2022/02/09 15:26:09 | at java.lang.Thread.run(Unknown Source)
INFO | jvm 1 | 2022/02/09 15:26:09 | I [o.e.j.s.AbstractConnector ] [21:26:09]: Started ServerConnector@4ed91a61{HTTP/1.1,[http/1.1]}{0.0.0.0:8088}
INFO | jvm 1 | 2022/02/09 15:26:10 | [Catapult] [1644441970845]: Uncaught exception during getContextState():
INFO | jvm 1 | 2022/02/09 15:26:10 | java.lang.NullPointerException
INFO | jvm 1 | 2022/02/09 15:26:10 | at com.inductiveautomation.catapult.Catapult$CatapultRequestReceiverImpl.getContextState(Catapult.java:296)
INFO | jvm 1 | 2022/02/09 15:26:10 | at com.inductiveautomation.catapult.Catapult$CatapultRequestReceiverImpl.requestReceieved(Catapult.java:731)
INFO | jvm 1 | 2022/02/09 15:26:10 | at com.inductiveautomation.catapult.CatapultRequestServer.handleRequest(CatapultRequestServer.java:60)
INFO | jvm 1 | 2022/02/09 15:26:10 | at com.inductiveautomation.catapult.CatapultRequestServer.access$100(CatapultRequestServer.java:27)
INFO | jvm 1 | 2022/02/09 15:26:10 | at com.inductiveautomation.catapult.CatapultRequestServer$RequestFileMonitor$2.run(CatapultRequestServer.java:118)
INFO | jvm 1 | 2022/02/09 15:26:10 | at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
INFO | jvm 1 | 2022/02/09 15:26:10 | at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
INFO | jvm 1 | 2022/02/09 15:26:10 | at java.lang.Thread.run(Unknown Source)
INFO | jvm 1 | 2022/02/09 15:26:11 | I [o.e.j.s.AbstractConnector ] [21:26:11]: Started ServerConnector@416d300e{SSL,[ssl, http/1.1]}{0.0.0.0:8043}
INFO | jvm 1 | 2022/02/09 15:26:11 | I [o.e.j.s.AbstractConnector ] [21:26:11]: Started ServerConnector@40e01a93{SSL,[ssl, http/1.1]}{0.0.0.0:8060}
INFO | jvm 1 | 2022/02/09 15:26:11 | I [o.e.j.s.Server ] [21:26:11]: Started @12789ms
INFO | jvm 1 | 2022/02/09 15:26:11 | [Catapult] [1644441971841]: Uncaught exception during getContextState():
INFO | jvm 1 | 2022/02/09 15:26:11 | java.lang.NullPointerException
INFO | jvm 1 | 2022/02/09 15:26:11 | at com.inductiveautomation.catapult.Catapult$CatapultRequestReceiverImpl.getContextState(Catapult.java:296)
INFO | jvm 1 | 2022/02/09 15:26:11 | at com.inductiveautomation.catapult.Catapult$CatapultRequestReceiverImpl.requestReceieved(Catapult.java:731)
INFO | jvm 1 | 2022/02/09 15:26:11 | at com.inductiveautomation.catapult.CatapultRequestServer.handleRequest(CatapultRequestServer.java:60)
INFO | jvm 1 | 2022/02/09 15:26:11 | at com.inductiveautomation.catapult.CatapultRequestServer.access$100(CatapultRequestServer.java:27)
INFO | jvm 1 | 2022/02/09 15:26:11 | at com.inductiveautomation.catapult.CatapultRequestServer$RequestFileMonitor$2.run(CatapultRequestServer.java:118)
INFO | jvm 1 | 2022/02/09 15:26:11 | at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
INFO | jvm 1 | 2022/02/09 15:26:11 | at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
INFO | jvm 1 | 2022/02/09 15:26:11 | at java.lang.Thread.run(Unknown Source)
