Weekly 7.9 Changelogs - 2020
This post contains changelog entries for weekly 7.9 builds available in 2020.
Weekly Changelog: 7.9.15-b20200611
Allen-Bradley Drivers
16468: Backport 16439: AB V21+ Driver Timeout when writing to bit tags
Prevents a timeout that occurs when attempting to write to bits with the Logix driver.
Vision
16501: Template Canvas: parameter values include additional quotes
Fixed an issue where additional quotation marks were being added to template parameter values entered into the Template Canvas Customizer’s user interface.
Weekly Changelog: 7.9.15-b20200630
Vision
12543: NPE thrown when having menu with no items configured and the menu bar is hidden
Prevents a silent error when launching a Vision Client with a menu bar containing no items, while the menu bar is set to be hidden.
16640: Vision cannot log into gateway behind AWS load balancer
Fixed an issue where vision clients were unable to login to gateways behind AWS load balancers.
Nightly Changelog: 7.9.15-b20200714
Ignition Platform
14915:Warn when client launcher JRE selection fails
Now aborting client launch if no system JRE can be found.
12211: Client won’t connect to backup node in specific scenario
Fixed an issue preventing Vision clients from connecting to backup gateways in certain redundancy scenarios.
Nightly Changelog: 7.9.15-b20200721
16808: Changing Datatype from INT to DINT in PLC prevents tag writes
Updated so that writes are able to proceed.
Ignition Platform
16801: Custom response handlers not executing for SECS-1/serial
The SECS-1 (serial) protocol can now use custom message response handlers.
Nightly Changelog: 7.9.15-b20200804
Ignition Platform
16785: runSFUpdateQuery() can cause store and forward to grow unbounded
Fixed an issue that resulted in entries added to Store and Forward by the system.db.runSFUpdateQuery function to never be deleted.
15246: Tag Import- Nested UDTs overrides are not imported
Fixed the issue that was causing the collisions.
16865: XSS vulnerabilities possible in various Gateway Web Pages
Fixed a set of XSS vulnerabilities discovered in the Gateway Web Interface.
SQLBridge
16791:SerializationException on save when transaction group items have alarms with bound associated data
Now able to save associated data without any issues.
Nightly Changelog: 7.9.15-b20200811
Alarm Notification
16841: Alarm Pipeline Block UI takes long to connect pipeline block lines
Improved performance of Alarm Pipeline Block UI.
Ignition Platform
16926:IllegalStateException from S+F cache updater task
Prevent IllegalStateException from S+F cleanup thread.
16070: Alarm Event Missing Information After Alarm Enabled Property Toggled
Fixed an issue where alarm event information was lost if the event was cleared while the alarm configuration was disabled.
SECS/GEM
16889:system.secsgem.sendRequest returns transaction id of 0 for SECS-1/serial
Fix SECS-GEM serial transaction id generation.
Siemens Driver
16921: Siemens Driver: Error optimizing read items
Fixed issue when multiple writes to same address were causing blocks to get overwritten.
Nightly Changelog: 7.9.17-b20201020
Enterprise
322: Backport: “Config Update Queue Size” to 7.9
The redundancy Config Update Queue Size setting is now adjustable and defaults to 100MB.
Nightly Changelog: 7.9.17-b20201201
Connectivity
870: DNP3 driver conformance level read issues for versions 7.9.13 - 7.9.16
Support parameter error when reading conformance level.
Data Model
140: Backport 16680: Clear Tag History Provider cache
Calls to system.tag.browseHistoricalTags will return updated results when tags under historical providers are added, removed, or edited without requiring a restart to the provider.
Nightly Changelog: 7.9.17-b20201208
Platform
325: Search/replace finds tags but no Tag Event scripts
Tag event scripts can now be searched for within designer find/replace.
Nightly Changelog: 7.9.17-b20201215
Security
1244: Set autoComplete=“off” for SignIn page’s username and password fields.
Autocomplete should now be disabled for the Gateway Web Interface Sign In page’s username and password fields.
Data Model
672: SFC chart recordings get deleted when trying to store multiple recordings.
Fixed an issue where SFC recordings were being pruned when they shouldn’t have.
1286: Driven scan class will initially default to 1000ms when using 0ms slow rate
Don’t subscribe new tags added to a driven class that is running at a 0ms slow rate.
