Weihenstephan protocol and Ignition
Hi All,
I have a filling machine that apparently has information available via the Weihenstaphan protocol. Has anyone used Ignition to communicate via this protocol before? I can connect to to OPC-UA server on this machine using UA-Expert, but when I try to connect with Ignition I get UaServiceFaultException: status=Bad_ServiceUnsupported, message=The server does not support the requested service.
I think I will ask the filling machine company to update the machine to support OPC-UA with Ignition. But they have mentioned the Weihenstephan Protocol
OPC UA should be the way forward.
Can you get a Wireshark capture of Ignition vs UaExpert connecting?
Hi Kevin,
Please find captures attached.
Cheers,
CheckMat_Ignition.pcapng (26.0 KB)
CheckMat_UAExpert.pcapng (67.2 KB)
Ok, yeah, you'll have to work with the vendor of this server. It looks like the server returns BadServiceUnsupported in response to a FindServersRequest.
You might be able to get connected if you use the "skip to advanced" part of the discovery wizard and put:
  • Discovery URL: opc.tcp://10.17.235.152:4850
  • Endpoint URL: opc.tcp://K731-E5U:4850
  • Endpoint Host Override: 10.17.235.152
  • SecurityPolicy / SecurityMode: None
