Today for no apparent reason one of our data source connections to one of our SQL servers stop working in the middle of the day. We received a call that some of the clients were receiving errors. When I checked the status of the connection it was yellow and said “this data source is being tested”. I tried making another connection to the same database and it would not connect with the same problem. There is another connection to the same server, but to a different database and the data source was green. I talked with the DBAs to see if they did anything and nothing had changed. After about 30 minutes of working with different connection parameters and checking processes ids in the SQL server I restarted the gateway service and everything worked fine again.
My question is what went wrong? Where could I look to see what caused the issue?
