Weird error on "insert into" script query
Hello guys
Please help me, this is driving me crazy
I'm trying to do an "insert into" query in a script
this is the query simplified
INSERT INTO mes.fr_furanic_register (groupkey) VALUES('a')
in postgre is working perfectly fine
when I'm trying in Perspective script tools or in a normal script
query = ''' INSERT INTO mes.fr_furanic_register (groupkey) VALUES('a') '''
system.db.runUpdateQuery(query)
I'm getting following error
Java Traceback:
  File "<input>", line 2, in <module>
	at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.error(AbstractDBUtilities.java:392)
	at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.runUpdateQuery(AbstractDBUtilities.java:188)
java.lang.Exception: java.lang.Exception: Error executing system.db.runUpdateQuery( INSERT INTO mes.fr_furanic_register (groupkey) VALUES('a') , , , false)
	at org.python.core.Py.JavaError(Py.java:547)
	at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:190)
	at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:553)
	at org.python.core.PyObject.__call__(PyObject.java:461)
	at org.python.core.PyObject.__call__(PyObject.java:465)
	at org.python.pycode._pyx6.f$0(<input>:2)
	at org.python.pycode._pyx6.call_function(<input>)
	at org.python.core.PyTableCode.call(PyTableCode.java:173)
	at org.python.core.Py.runCode(Py.java:1687)
	at org.python.core.Py.exec(Py.java:1731)
	at org.python.util.PythonInterpreter.exec(PythonInterpreter.java:277)
	at org.python.util.InteractiveInterpreter.runcode(InteractiveInterpreter.java:130)
	at com.inductiveautomation.ignition.designer.gui.tools.jythonconsole.JythonConsole$ConsoleWorker.doInBackground(JythonConsole.java:628)
	at com.inductiveautomation.ignition.designer.gui.tools.jythonconsole.JythonConsole$ConsoleWorker.doInBackground(JythonConsole.java:616)
	at java.desktop/javax.swing.SwingWorker$1.call(Unknown Source)
	at java.desktop/javax.swing.SwingWorker.run(Unknown Source)
Caused by: java.lang.Exception: Error executing system.db.runUpdateQuery( INSERT INTO mes.fr_furanic_register (groupkey) VALUES('a') , , , false)
	... 26 more
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Cannot run this function when in read-only mode.
	at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.getResponse(GatewayInterface.java:393)
	at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:292)
	at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:287)
	at com.inductiveautomation.ignition.client.script.ClientDBUtilities._runUpdateQuery(ClientDBUtilities.java:267)
	at com.inductiveautomation.ignition.common.script.builtin.AbstractDBUtilities.runUpdateQuery(AbstractDBUtilities.java:181)
	... 24 more
I've already tried using variables like this
a = 'ciao'
query = ''' INSERT INTO mes.fr_furanic_register (groupkey) VALUES('%s') '''% (a)
same error except for the line nr
I've also tried runPrepUpdate ... nothing changes
Please help me
You need to set your Designer to read/write mode to run insert/update queries.
thanks a lot
so dumb ....
