I’ve attached the log file. There WILL be a lot of odd entries in it as I was trying different addressing schemes.
The symptom I am trying to figure out is when writing a ONE/true to a single memory bit location, it always throws a bad quality error. YET…it does successfully write the value. When writing a ZERO, it never throws an error. Period. Only when writing a one. I know the writes in the end are successful as the PLC program I have running is simply firing output coils based upon those memory address bits being 1 or 0 (just a protocol test ladder logic program I put together to make sure all this was working fine).
The PLC is a Hollysys LM3108 connected via a DIGI One IA, via a VPN tunnel back to ignition running at the office. Protocol is Modbus. I know…remove all the middle components to reduce/identify the potential problems (which I intend to do Monday, but in the end this will be the equipment used in this application).
logs.bin.gz (254 KB)
