The path in the above DataArray structure is bound with an expression binding using the tagpath parameter and the suffix to reach the member in the UDT that has the tag history enabled (e.g. [default[G20_PI_301/OUT )
We then have a table and a timeseries chart (the problem happens to each component equally the same, however it's easier to see what is happening in the table so I will present that here) that is then doing a tag history binding based on the DataArray structure
Does anyone have any idea why this is happening??? I suspect that the historical binding, which refers to the expression binding to a property which includes a parameter is not able to be evaluated (but only in the browser, not the designer) because of a possible race or circular logic condition which is then fixed when the parameter is treated as an output?
What we are basically trying to do is to provide a 10 minute trend in our popup for sensors. How is everyone else passing a partial tagpath to a popup and then generating a trend or table with historical data?
First troubleshooting step with anything related to passing params is toss labels on each layer of the views that links the text to your param so you can visually see its valid along each section. When you get to tiers of embedding and such it's very useful.
Otherwise the first step I'd try to enable polling at a few seconds in your tag history binding. That will tell you if its a race condition related to initial loading since it'll re-poll shortly again after loading.
What I ended up doing was re-creating my embedded views and popups. I think the issue was that I was using the same paramater name in my embedded view and then passing that to the popup with a paramater with the same name.
When i changed the embedded view parameter to tagp and in my popup open action to pass that value to tagpath the trends started to work fine. It's a bit strange but it's almost as if there is something in the browser that causes issues when you have parameters with the same name.
I would have suspected the parameter passing bug to be causing this, which causes the tagpath param to simply not be passed in at all and the embedded view uses its default saved value instead. Although this generally only happens with non-"value" data types (ie arrays and objects)
