We have noticed some very strange behavior in the Vision Client when a window that includes template-based graphics is displayed. If the window is left open long enough for the logged-in user to be logged out automatically (30 minutes) on inactivity the templates often (not always) get screwy. If you have a window with 10 instances of the same template (all pointing at different data sources), some will get gray overlays and some will get red bad configuration overlays. Styles for multi-state indicators will change so that colors and text are not as they should be. Data values will become incorrect - the number on the display will no longer agree with the value in the SQL tag browser.
Everything reverts to normal when you log in or when you navigate to a different window and return to the misbehaving one without logging in.
Numeric and multi-state indicators that are pointing at the same data sources but are not parts of templates are not affected.
If you have 10 template instances on the screen only 3 or 4 will be affected. The template instances that are affected are not consistent between occurrences.
This appears to be a major nuisance bug with Ignition v7.7.1. We have confirmed it on two different systems.
