Hello!
I´m doing a dashboard to show some data from gateway tags.
What tags from Gateway would users be interested to look at?
Any suggestions or ideas are welcome.
This is what I have for now:
I would write a small script to convert the uptime seconds to a readable elapsed time showing days, hours, minutes, and seconds.
What about device connections? Do you have it on a separate page? If not, it wouldn't hurt to show the status of all those connections also.
I would change this to a mapping transform instead of a script transform. Make it with only 1 value of "Connected" and the fallback, and you can then even select a color for the mapped value so you can pick the exact shade you want from the dialog. This should also be faster and more efficient in terms of performance.
Change the output Type from Value to Color
Or, better, change it back to value and use the theme colors, --success and --error. (I can't remember if you need var(--success) in this case.) Of course, you are using theme colors everywhere else, aren't you? ![]()
Too many colors!
Yes, you right, the checkbox are on the guidelines, and the 2 shades of orange, you got me. Will change those!
apart form that I like many colors on different panels
idk how you selected your colors, but might be a good idea to look at something like this if you want lots of colors. if you havent already
Thanks @victordcq , those are company colors guidelanes, aniways as Transistor sugest I will use them more safely. Cheers!
If the company has such a big pallet, than it might be a good idea to replace all theme colors with them.
For example the checkbox could be the "company light blue" instead of the default blue. or the green enabled displays.
I guess.
This 7 is kinda hard to read, you shouldnt use dark backgrounds behind greyish letters. Keep the letters black and/or use a different blackground
But i dont really know anything about colors xd
But they should mean something (or be part of a company branding)! Otherwise it looks like a child got hold of a box of eye-shadow colors and went mad! They are a visual distraction. It takes the user several seconds to go, "Colors! - what do they mean? - I can't see a pattern - there isn't one, is there - no, I don't think so - OK, try to ignore the colors!"
yep, will try improve those, not mucha about panels in the guidelines but propably using plain grey for all is good idea.
One tag that I created and is quite useful for my (global) project is number of perspective clients. I create a tag that is populated 1/min with a script of
tagVal = system.perspective.getSessionInfo()
We have a lot of users so I want to make sure we have enough hardware resources to accomodate.
Another thing I look at often is error/warnings from the GW log. Especially the logs that my (broken) scripts create.
Thanks a lot DNice, I will include those, very helpful!
