Hi
I have started getting this error in the past few days. It is happening 4 or 5 times a minute. Just wondering what is causing it. I am using 7.2.4. I have recently deleted many tags, would this be what is causing it ?
Aidan
wrapper.txt (1 MB)
Deleting the tags is probably what caused it but it looks like a bug; it’s not something that should be there. I’ll look into it a bit and see what I can find.
It should go away if you force the UA connection to reconnect (edit/save without changing anything) or restart the gateway.
Hi Kevin
I restarted the gateway at the weekend which stopped the errors. I would have disabled the tags before deletion which might help trying to figure out the errors
Aidan
