What format is the wrapper log?
Dumb Linux question… How do I open the wrapper log? This is my rpi4 debian environment
Raw bytes. Most content should be utf-8, but loggers might not respect that… Use kate or another code-capable editor.
Any text editor should be able to open wrapper.log files… the logs .idb you export from the gateway is another story.
I’ve tried both “Text Editor” and Geany, but neither can open it :confused: If I copy it to Windows, no problems reading it…
Q: On a side note, how can I remove a module if I can’t get the gateway booted?
Edit:
A: Delete the modl file from the user-lib directoy
Can you upload this wrapper.log somewhere?
I just opened it with nano. I was also able to grep the log directly from the terminal. Does nano wrapper.log work?
