I had custom styles props, like grid and z-index on a few projects. I wanted to do some custom styling on another project but I cannot add custom props any longer to the styles property.
What's the go-to now?
And, for the grid, I now see a class listed, but there is no actual class in the styles folder. Edit: Oh I see that class now in the styles sheet...
I guess it's all in the style sheet now!
Are you talking about custom styles using a component's props.styles prop, or perspective styles as in what you select to go into props.styles.classes?
You can still add whatever you want manually into props.styles. Adding simple properties into p styles I would still "parisitise" another benign property you're not using in the ui by ending it with ; and then adding the prop name and value pair in its place:
; gap: 5px
just make sure to use the css name of the prop which are kebab-case
For any more complex additions to a p style, I would also define a blank p style for it and then provide the content of its definition inside the stylesheet
props.styles.
There used to be a blue plus icon next to the "modify style" icon.
8.1.43
Matter of fact, I don't see that plus icon after any property, anywhere!
Except for adding custom props/params...
Edit: version 45. Looking at the wrong number
Ah, that's a bug. You can get it back with some jiggling.... It's a bit of an art
That's a technical term, right? Do you recommend smacking the computer around a little or taking the designer and shaking it with the mouse?
Finally got it back! Almost broke the computer in the process though...
It's definitely the technical term, although for the context I used it in, I'm not so sure
