Hello,
I have a mainview that consist of a map-view and a selectbar-view. When I select something on the selectbar it navigates my map-view without a problem because the map-view and the selectbar-view are both embedded in the mainview and the selected parameter can be sent to the map
( Property/parameter binding between views - #4 by theodor_skaufel ). However, I am having trouble figuring out the best way to pass the same navigational paramater to a view that is not embeded in the mainview.
This is for a marker popup on the map with information on the selected location that is shown on the map when selected in the selectbar-view.
The popupview is not embedded in the mainview as it is referenced directly from the map components marker-popup-function.
Should I use a message handler script or maybe embed the popup-view in the mainview but hide it?
I cannot write the param in question to a tag because multiple users will affect each others sessions by updating the same tag.
