Working on Vision, Chart component in configureChart Extension Function.
I’m trying to rewrite and/or hide some pens name that is appearing in the legend. I’m trying to use the method setSources() that needs LegendItemSource interface.
I’m implementing this with
class MyLegendItemSource(LegendItemSource):
def getLegendItems(self):
return legendItemsOverride
when I call the method’s class I’m getting:
print MyLegendItemSource().getLegendItems()
output: org.jfree.chart.LegendItemCollection@56a7d44b
However, when I attempt to set the source with legend.setSources(MyLegendItemSource()). Where legend = chart.getLegend()
I’m getting this:
[AWT-EventQueue-0] ERROR Vision.ClassicChart - Error invoking extension method.
org.python.core.PyException: Traceback (most recent call last):
File "<extension-method configureChart>", line 68, in configureChart
TypeError: setSources(): 1st arg can't be coerced to org.jfree.chart.LegendItemSource[]
at org.python.core.Py.TypeError(Py.java:235)
at org.python.core.PyReflectedFunction.throwError(PyReflectedFunction.java:209)
at org.python.core.PyReflectedFunction.throwBadArgError(PyReflectedFunction.java:312)
at org.python.core.PyReflectedFunction.throwError(PyReflectedFunction.java:321)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:167)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:204)
at org.python.core.PyObject.__call__(PyObject.java:404)
at org.python.core.PyObject.__call__(PyObject.java:408)
at org.python.core.PyMethod.__call__(PyMethod.java:124)
at org.python.pycode._pyx1702.configureChart$1(<extension-method configureChart>:68)
at org.python.pycode._pyx1702.call_function(<extension-method configureChart>)
at org.python.core.PyTableCode.call(PyTableCode.java:165)
at org.python.core.PyBaseCode.call(PyBaseCode.java:301)
at org.python.core.PyFunction.function___call__(PyFunction.java:376)
at org.python.core.PyFunction.__call__(PyFunction.java:371)
at org.python.core.PyFunction.__call__(PyFunction.java:361)
at org.python.core.PyFunction.__call__(PyFunction.java:356)
at com.inductiveautomation.vision.api.client.components.model.ExtensionFunction.invoke(ExtensionFunction.java:152)
at com.inductiveautomation.factorypmi.application.components.PMIChart.createChartImpl(PMIChart.java:489)
at com.inductiveautomation.factorypmi.application.components.chart.PMILineChartPanel.createChart(PMILineChartPanel.java:136)
at com.inductiveautomation.factorypmi.application.components.PMIChart.setExtensionFunctions(PMIChart.java:474)
at com.inductiveautomation.factorypmi.designer.eventhandling.ComponentScriptEditor.applyChanges(ComponentScriptEditor.java:599)
at com.inductiveautomation.factorypmi.designer.eventhandling.ComponentScriptEditor.access$600(ComponentScriptEditor.java:85)
at com.inductiveautomation.factorypmi.designer.eventhandling.ComponentScriptEditor$4.actionPerformed(ComponentScriptEditor.java:330)
at java.desktop/javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at java.desktop/javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at java.desktop/javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at java.desktop/javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at java.desktop/javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
at java.desktop/java.awt.EventQueue.access$500(Unknown Source)
at java.desktop/java.awt.EventQueue$3.run(Unknown Source)
What I missing since is not the first time I’m implemeting an interface.
