What Minimum Sample Rate should be used to capture only On Change for a discrete tag?
We have a discrete tag that I only want to record history when the tag changes. I don't need a minimum or maximum time between samples. Will a setting of 0 for both Min and Max remove any min and max time sample when sample mode is On Change?
Thank you in advance!
Yes, 0 will remove any time and only capture on change.
Thank you! Did I miss that in the documentation somewhere, or did you test it and figure it out on your own?
I just assumed 0 would never sample. My assumption just turned out to work lol.
