Hello,
I want to remove the space after my rows, I did it before but I forgot what propriety . any help? thank you.
I'll assume this is in a flex container.
uncheck the props.virtualized property, then set position.basis: auto
thank you for your reply, it's already virtualized false and auto for basis and yes it's inside a flex container
What's the direction of the container ?
If it's column, that's all you need and it should work.
edit: And set grow to 0.
grow=0 made it work, thank you.
