One of our sites is running 8.1.44, has one database and a multiple connections to that database. One connection per project for a total of about 30+ ish.
Going back to my 7.7 days, I recall this being an issue with the way the tag history is stored, tables being locked, and a few other things as the connections to the tables were not aware of each other.
From my understanding, they just wanted to control the database access to each project, no other reason for the multiple connections.
Before I tell them that they should consolidate their db connections, I wanted to make sure my information is accurate.
Are there any issues having the 30+ connections to the same database and tables?
Are you saying there are 30 database connections configured in the gateway, all pointing to the same database?
An issue i've come across is that if you have duplicate connections to the same gateway, and one has pruning, the prune doesn't recognise the different "connection", and will apply to all pf the Ignition tables. Differences in the sectioning (ie weekly/monthly) can also cause trouble.
Additionally, this also just sounds painful to manage?
It's possible to have multiple schemas within the same database for different purposes, and each schema can be connected to Ignition using separate connections without any issues. I wouldn't expect any problems even with around 30 separate schemas. However, if we're talking about 30 separate connections to the same schema and tables, I would need to hear the reasoning behind this before I would consider accepting it.
Yes, because every configured database connection is actually a pool of connections, eight by default. So, unless you've tailored that, your 30+ connections is really 240+ on the DB side. That can be a real disaster for DB resource management, as they will all have the same priority.
This is a terrible reason, as there's no "control" separating the projects' access to each others' databases.
I agree, I have an email ready to send to the site explaining the issues but I didn't want to say it was bad. I wanted to explain why they should consolidate the connections.
I appreciate the info!
