What's in your nginx conf?
Playing around with a maker setup on docker compose.
Does anyone have a solid Nginx conf file they can share?
This is mine. But, I can’t get the designer to render it yet. I haven’t got it to attach to the SSL port yet either. By changing the upstream gateway port. It doesn’t work.
# Ignition server
upstream gateway {
 server gateway:8088;
server {
    listen 80;
    server_name <{DOMAIN-NAME}>; # *** replace with your domain change in ssl paths too ***
    server_tokens off;
    location /.well-known/acme-challenge/ {
        root /var/www/certbot;
    location / {
        return 301 https://$host$request_uri;
server {
    listen 443 ssl;
    server_name <{your domain}>;
    server_tokens off;
    ssl_certificate /etc/letsencrypt/live/<{DOMAIN-NAME}>/fullchain.pem;
    ssl_certificate_key /etc/letsencrypt/live/<{DOMAIN-NAME}>f/privkey.pem;
    include /etc/letsencrypt/options-ssl-nginx.conf;
    ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem;
location / {
                proxy_http_version 1.1;
                proxy_cache_bypass $http_upgrade;
                proxy_set_header Upgrade                $http_upgrade;
                proxy_set_header Connection             "Upgrade";
                proxy_set_header Host                   $host;
                proxy_set_header X-Real-IP              $remote_addr;
                proxy_set_header X-Forwarded-For        $proxy_add_x_forwarded_for;
                proxy_set_header X-Forwarded-Proto      $scheme;
                proxy_set_header X-Forwarded-Host       $host;
                proxy_set_header X-Forwarded-Port       $server_port;
                proxy_pass http://gateway; #Use ignition container ip address
        location /system/images/ {
        location /data/perspective/ {
        location /res/perspective/ {
        location /system/perspective-download/ {
        location /system/pws/ {
        location /system/gwinfo {
docker-compose.yml
version: '3.1'
services:
  nginx:
    image: nginx:1.15-alpine
    restart: unless-stopped
    volumes:
      - ./data/nginx:/etc/nginx/conf.d
      - ./data/certbot/conf:/etc/letsencrypt
      - ./data/certbot/www:/var/www/certbot
    ports:
      - "80:80"
      - "443:443"
    command: "/bin/sh -c 'while :; do sleep 6h & wait $${!}; nginx -s reload; done & nginx -g \"daemon off;\"'"
  certbot:
    image: certbot/certbot
    volumes:
    entrypoint: "/bin/sh -c 'trap exit TERM; while :; do certbot renew; sleep 12h & wait $${!}; done;'"
  gateway:
    image: kcollins/ignition:8.1.4  # You can change `latest` to a specific version, e.g. `8.0.5`
    ports:
      - "8088:8088"
      - "8043:8043"
    stop_grace_period: 30s
    secrets:
      - gateway-password
    volumes:
      # - ./gateway_backup.gwbk:/restore.gwbk
      - gateway_data:/var/lib/ignition/data
    logging:
      driver: "json-file"
      options:
        max-size: "200k"
        max-file: "10"
    environment:
      - GATEWAY_ADMIN_PASSWORD_FILE=/run/secrets/gateway-password
      - IGNITION_EDITION=maker
      - IGNITION_LICENSE_KEY=<your key>
      - IGNITION_ACTIVATION_TOKEN=<your token>
  db:
    platform: linux/x86_64
    image: mysql:5.7
    ports:
      # Note that the 3306 port doesn't need to be published here for the gateway container to connect,
      # only for external connectivity to the database.
      - "3306:3306"
    volumes:
     - db_data:/var/lib/mysql
    logging:
      driver: "json-file"
      options:
        max-size: "200k"
        max-file: "10"
    secrets:
      - mysql-root-password
      - mysql-password
    environment:
      # See https://hub.docker.com/_/mysql/ for more information
      MYSQL_ROOT_PASSWORD_FILE: /run/secrets/mysql-root-password
      MYSQL_DATABASE: ignition
      MYSQL_USER: ignition
      MYSQL_PASSWORD_FILE: /run/secrets/mysql-password
secrets:
  mysql-root-password:
    file: ./secrets/MYSQL_ROOT_PASSWORD
  mysql-password:
    file: ./secrets/MYSQL_PASSWORD
  gateway-password:
    file: ./secrets/GATEWAY_PASSWORD
volumes:
  gateway_data:
  db_data:
