When using system.dnp.directOperateBinary the Designer waring that ”object has no attribute 'dnp'“
Button Script:
deviceName = "NPORT"
index = 0
tcc = 0
opType = 1
count = 1
onTime = 0
offTime = 0
system.dnp.directOperateBinary(deviceName, index, tcc, opType, count, onTime, offTime)
Waring:
File "event:actionPerformed", line 9, in
AttributeError: 'com.inductiveautomation.ignition.common.script.Imm' object has no attribute 'dnp'
at org.python.core.Py.AttributeError(Py.java:176)
at org.python.core.PyObject.noAttributeError(PyObject.java:965)
at org.python.core.PyObject.__getattr__(PyObject.java:959)
at org.python.pycode._pyx131.f$0(<event:actionPerformed>:9)
at org.python.pycode._pyx131.call_function(<event:actionPerformed>)
at org.python.core.PyTableCode.call(PyTableCode.java:173)
at org.python.core.Py.runCode(Py.java:1703)
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:804)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.runActions(ActionAdapter.java:207)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.invoke(ActionAdapter.java:300)
at com.inductiveautomation.factorypmi.application.binding.action.RelayInvocationHandler.invoke(RelayInvocationHandler.java:57)
at jdk.proxy2/jdk.proxy2.$Proxy61.actionPerformed(Unknown Source)
at java.desktop/javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at java.desktop/javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at java.desktop/javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at java.desktop/javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at java.desktop/javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
at java.base/java.security.AccessController.doPrivileged(Unknown Source)
at java.desktop/java.awt.EventQueue$5.run(Unknown Source)
Ignition v8.1.36 (b2024010211)
Java: Azul Systems, Inc. 17.0.8
Try to run in Script console
Waring:
File "", line 9, in
AttributeError: 'com.inductiveautomation.ignition.designer.gui.tool' object has no attribute 'dnp'
Are you using the legacy or the new DNP driver?
Have you used auto complete (ctrl + space) to check what script libraries are available? I've never used the dnp3 libraries before and don't know if they're available in non-gateway scopes
Thanks for reply
It is my mistake.
I run the script on Vision side
It can run on perspective as well
