Anyone use this before where the contents of IN are dynamic?
I need to create a query where the contents of the WHERE IN (x,y,z) are the result of a another query. Only way I can figure out to do it is in scripting, where I have to build the contents of (x,y,z) with various strings.
Is there a simplier way?
Not really. To be really safe, you should construct a variable number of ‘?’ placeholders, then pass the appropriate length list of values in a Prep query. Bindings generally aren’t sufficiently flexible, which is why I created objectScript(), my generic “get out of jail free” card.
If you aren’t manipulating the results of the other query you can do something like this.
SELECT *
FROM Table1
WHERE ID IN (SELECT ID FROM Table2)
[quote=“jpark”]If you aren’t manipulating the results of the other query you can do something like this.
SELECT *
FROM Table1
WHERE ID IN (SELECT ID FROM Table2)[/quote]
Thanks Jae,
that worked for me :
[code]SELECT
a.t_stamp as 'Time',
b.Description as 'Tecnal Mold',
a.tank as 'Ferm Tank',
a.prodQty as 'Ferm Qty',
a.rennet/1000 as 'Rennet Inject',
a.runid
FROM
tecnal a
LEFT JOIN tecnalproducts b ON a.productID = b.id
WHERE RunID IN
(SELECT
a.ID
FROM
htstruns a
WHERE
Silo1ID = {Root Container.SiloID.value} OR
Silo2ID = {Root Container.SiloID.value}
[/code]
