Hi!
Inside Ignition jsonschema library there is this code:
1 try {
2 URL url = new URL(schemaUrl);
3 parentSchema = factory.getSchema(url);
4 } catch (MalformedURLException var10) {
5 InputStream is = Thread.currentThread().getContextClassLoader().getResourceAsStream(schemaUrl);
6 parentSchema = factory.getSchema(is);
7 }
Where schemaurl is the path to the file.
However, the line 5 always return nulls. I have been searching and found this.
As you may see, that line executes from the top of the class path, and if I put a wrong path it doesn't get the file.
My question is:
Where is the top of the class path? It is dependent or I'm doing something wrong?
This function is inside a library that is called from a python file whose function is called using a button.
