Hi All,
Good day! Hope you all doin’ well.
Is anyone here knows where to locate the alarm cache file in install directory folder.
What type of file is it?
Thanks.
-JR
Hi All,
Thanks.
-JR
The alarming cache is opaquely serialized data in an undocumented format. It’s located in the install directory, in data/, and will have a name like .alarms_${someLongInteger}.
Hi PGriffith,
Thanks for your fast reply.
I don’t know why I can’t see that file.
Should the gateway needs to be stop before it appear on that folder? Should it have an active alarm?
The main reason why I asked where the alarm cache file is located is that I can’t acknowledge my active alarm and it generate a logged stating "An alarm could not be acknowledged. It may no longer be registered. Event details:****… "
But anyway, my problem solved after I restarted the gateway.
Thanks a lot PGriffith.
